    The cart summary in the header does not include the added products
    Posted by: juanitodejabu May 4, 2023 at 23:34 (2 year ago)
    Hello, I tell you that there is a bug with the subject, when I add a product to the shopping cart, the added product does not appear in the cart summary in header. It should load automatically as soon as I add the product to the cart. I wait for your help.
    Posted by: yame, May 5, 2023 at 02:21 (2 year ago)
    Hi @juanitodejabu,
    I also sent your issue to my coder. He will help you to check it and I will inform you later when I get his answer.
    Posted by: juanitodejabu, May 17, 2023 at 18:52 (2 year ago)
    Hello, I'm waiting, it's been 12 days.
    Posted by: yame, May 18, 2023 at 02:30 (2 year ago)
    Oh, I am really sorry. My coder sent the answer in the box chat, but I missed it.
    Thanks for reminding me here.
    It is because of this plugin: https://prnt.sc/mgUjk-f-n9EX
    He guessed that you might use this plugin to customize the mini-cart or anything, so it led to the problem that the item in the cart was lost.
    So pls try to deactivate the plugin and check your site again.
