    Change Woocommerce popup notice
    Posted by: WSiteDesign Aug 24, 2022 at 16:15 (2 year ago)
    How can I change the text of the woocommerce notification that appears when I add a product to my cart? Can you tell me where or how to change it .
    Posted by: yame, Aug 25, 2022 at 01:11 (2 year ago)
    Hi @WSiteDesign
    You can install a plugin named Loco Translate. This is a free plugin and you can translate the remaining texts on your site,
    Or you can provide me with your admin account, I will install this plugin and check it for you
