    Sticky menu is off globally but top nav still fixed on homepage - header style 15
    Posted by: andtay2001 Jun 16, 2021 at 10:57 (4 year ago)
    I have sticky menu disabled under header global options but it's still fixed on the homepage.
    https://www.chufd.co.uk
    Again it would be useful if the footer / header options could be totally removed under individual pages as they still seem to appear with meta option disabled.
    Andrew
    Posted by: andtay2001, Jun 16, 2021 at 11:10 (4 year ago)
    Adding attachment
    Posted by: Maason, Jun 17, 2021 at 17:24 (4 year ago)
    Hi andtay2001
    I sent to the author of theme. I will inform you when i get the answer from them
    Posted by: andtay2001, Jun 24, 2021 at 12:14 (4 year ago)
    The header is now not appearing at all;
    https://www.chufd.co.uk/
    It's enabled but the html isn't in the source code at all.
    Andrew
    Posted by: Maason, Jun 24, 2021 at 15:39 (4 year ago)
    Hi andtay2001
    The cause by your customize work on the child theme because when i activate the main theme then it works. Please check your changed on theme please. I can not help because i do not know what and where are you changed.
    Posted by: Maason, Jun 24, 2021 at 15:43 (4 year ago)
    You can remove this tag on childtheme
    Posted by: Maason, Jun 24, 2021 at 15:44 (4 year ago)
    here also
    Posted by: andtay2001, Jun 28, 2021 at 15:07 (4 year ago)
    Hi Maason,
    I'm still not able to see the header even with the changes or switching to the parent theme.
    The child theme only really has CSS changes and I started to look at changing the portfolio single template.
    Andrew
    Posted by: Maason, Jun 29, 2021 at 15:08 (4 year ago)
    Hi andtay2001
    I don't know what you did on the child theme. Are you a coder? As i mentioned above that i wont support for customized work. I support for the default theme only. In your case also, you have to fix by yourself or connect to customized services, they will check and help you..
