    Cannot get footer to work correctly in boutique theme
    Posted by: kberkbuegler Aug 27, 2020 at 20:55 (4 year ago)
    I cannot figure out how to add a footer in the Boutique theme. I have tried creating one on my own, but its not working. The document says there are pre-configured ones, but they do not appear to be loaded. The support document also states that it would walk me through how to create these, but I see no information in the document other than screen shots of setting one of the premade footers from the drop down which do not exist. I tried creating my own, but I have no idea what to do or how to make it work. It just appears to be duplicating my homepage at the bottom with a black background. If you would be able to assist me or tell me how to actually import these premade ones, I would like to use one. Also, how would I get an image into the header like you have pictured in some of the premade designs?
    Posted by: yame, Aug 28, 2020 at 02:32 (4 year ago)
    Hi @kberkbuegler,
    I don't understand. I still create a new one by adding the default template of the theme: https://prnt.sc/u77m98
    Could you please take the screenshot for your question? Then I will check again
    Awaiting your reply
    Posted by: kberkbuegler, Aug 28, 2020 at 04:50 (4 year ago)
    Thankfully this is just a demo at the moment, but I removed the one created and tried it on my own and all I am getting is the homepage duplicated in the footer area and its black. Screen shot attached
    Posted by: kberkbuegler, Aug 28, 2020 at 05:05 (4 year ago)
    I might have figured it out
    Posted by: yame, Aug 31, 2020 at 02:23 (4 year ago)
    Ohh. Great.
    So I will close this ticket if you don't have any other questions. Pls submit a new one when you need help
