    Product Single View
    Posted by: helixit Sep 25, 2019 at 18:40 (5 year ago)
    1. As you can see the product features get a line break which cause an error with the Dropdown elements. How can i fix this?
    2. All the DropDown Elements from the product-features should start on the same line / same hight / same width. How can i fix this?
    3. As you can see on the screenshot when you have some more categories they will be visible and will start on the same line as the title "categories, SKU and tags" but they'd should have a "move-in" and start on the same line as "Discacciati..." you know what i mean?
    Posted by: yame, Sep 26, 2019 at 03:35 (5 year ago)
    In all your tickets, pls check again your accounts. Then I will help you to check
    Posted by: helixit, Sep 26, 2019 at 06:27 (5 year ago)
    Thank you for your answer. I checked the accounts and the WP-Admin and also the FTP-Account works well - did you get an error or something?
    Posted by: helixit, Sep 26, 2019 at 06:30 (5 year ago)
    secret info.
    Posted by: yame, Sep 26, 2019 at 08:23 (5 year ago)
    Thanks. I will collect all your issues then send to my coder. He will check all for you
    Posted by: yame, Oct 3, 2019 at 08:44 (5 year ago)
    OMG. Sorry. My coder fixed the problem for you but I forget to inform you
    He updated theme for you and this problem was solved. Pls check
