    logo change in the footer
    Posted by: soennah-dokter Aug 23, 2019 at 14:02 (5 year ago)
    where can i change the logo in the footer. i cant find the option for it.
    see image by the attachment files
    Posted by: yame, Aug 26, 2019 at 01:11 (5 year ago)
    This is the logo in Footer. So,
    - Firstly, you have to check which Footer you are using for your site. Please negative to: Theme Options > Footer: http://prntscr.com/oxg9s6
    - Secondly: Negative to Ovic Panel > Footer Builder then edit for your Footer Builder you have checked in Theme Options: http://prntscr.com/oxgaao
    - Lastly: Please replace the demo logo image by yours: http://prntscr.com/oxgaiz
    If you still cannot do this, pls provide me your admin account, I will check in the site for you
    If you are satisfied with our support, would you please spend a little time to give us a good review + 5 stars on website https://themeforest.net/item/biolife-organic-food-wordpress-theme/reviews/22239723. It's really very worth with me.
