    Theme running poorly
    Posted by: dboland1 Aug 9, 2018 at 09:01 (7 year ago)
    Hi, I am having issues with this site - the Index.php file is killing my resources, and has done so since I first installed the theme.
    The only way I can negate the issue is by changing the file permissions on the file.
    Can you please help me at all. The site and theme are pretty much unusable...
    Posted by: Kazim Vu, Aug 10, 2018 at 01:03 (7 year ago)
    Good morning
    Your site does not work. Please check and provide your wp-admin login + FTP accounts again. I will check and help you. Also may i remove all demo contents and re-install from scratch?
