    Blog tags separation problem
    Posted by: efgieel Jul 15, 2016 at 13:22 (9 year ago)
    HI, when using your BLOG system, when I type tags and then I want to click on tags listing (left side block) they are not valid.
    Seems there is separation missing between tag words.
    Check block on the left.
    All update was made few days ago.
    Posted by: efgieel, Jul 21, 2016 at 09:24 (9 year ago)
    As you can see, I had to put "-" between keywords.
    When I create post there is a column for keyword, putting there only keyword with no "-"separation gives result in tabs as empty space between url adres.
    Please do me a favour and type some keywords in proper section when create blog / save and ten click on tab column you will see what I am talking about.
    ps. there are still not resolved issues with serach and listing. It has been 1 month since I started this topic..
    Posted by: efgieel, Jul 25, 2016 at 08:05 (9 year ago)
    This is not related to module attachment.
    Please delete /NEW/ from the adress, we went online now.
    check blog at http://blowupdesign.pl/blowupdesign-blog.html
    spot the difference with your tags build and read agai what i wrote at the beggining.
    Posted by: efgieel, Aug 24, 2016 at 08:14 (9 year ago)
    Is this solved??? How long I have to wait ???
    Posted by: yame, Aug 25, 2016 at 03:42 (9 year ago)
    Hi mate.
    We really appreciate for your patience. We know that it affected to your work.
    Our coder will check your problem in this afternoon and give you the solution as soonest as possible.
    Hope that you will give us a time and understand for this.
    Sincerely,
    Posted by: efgieel, Sep 1, 2016 at 14:51 (9 year ago)
    Anything in this matter?
    Posted by: yame, Sep 8, 2016 at 02:34 (9 year ago)
    We apologize for this delay reply just because my coder has just finished updating this theme.
    About your issue, please check your site again >> edit all your texts on Tag blog >> Clear cache and check your problem again. Our code has fixed it.
    For any queries please feel free to contact us.
    Sincerely,
    Posted by: yame, Sep 22, 2016 at 07:23 (8 year ago)
    Hi mate.
    My coder has fixed your issue related to Blog tag and updated this.
    You can go to themeforest.net, follow the change_log there to update the needed files. PLEASE REMEMBER to BACKUP both your database and source code before updating if you do not want to lose all your earlier setting.
    We hope that your issue will be solved soon.
    Regards.
    Posted by: efgieel, Sep 22, 2016 at 09:23 (8 year ago)
    ok, it gives results.
    Posted by: efgieel, Sep 22, 2016 at 09:49 (8 year ago)
    Question as below:
    Posted by: yame, Sep 23, 2016 at 01:44 (8 year ago)
    Thanks for your Invitation to collaborate. I am the local person.
    We are very honored to become collaborators with the other software development services. That will always bring customers get the service to develop. Hope that you will visit our country in the near future.
    If you are satisfied with us support, would you please spend a little time to give us a good review + 5 stars on website http://themeforest.net/downloads. It will be the encouragement for us to do this job.
    Best regards.
